[COLLECTION WDA] - Les Pentium
Cliquez pour agrandir
Type: Microprocessor
Introduction date 03/27/1995
Manufacturing process 0.6 and 0.35 micron
3.2 million transistors
Data bus width: 32 (64 bit data bus) bit
Package: 296-pin Staggered Ceramic Pin Grid Array, 1.95" x 1.95" (4.95 cm x 4.95 cm)
Socket: Socket 5 or Socket 7
Speed (MHz): 120
Bus frequency (MHz): 60
Clock multiplier: 2
Physical memory (GB): 4
Level 1 cache size: 8 KB code and 8 KB write-back data
Floating Point Unit :Integrated
ICOMP 2 index: 100
Min/Recommended/Max V core (V): 3.135 / 3.3 / 3.6
Min/Max operating temperature (°C): 0 - 70
Min/Typical/Max power dissipation (W): 1.76 / 5.06 / 12.81
Upgrade options Pentium MMX overdrive 180
CPUID: 052Ch
252Ch
Manufacturing stepping cC0
Notes on sSpec SL22M:
Boxed Pentium processor with an attached fan heatsink.
Modifié en dernier par Casio le 28 sept. 2026, 12:39, modifié 2 fois.
Introduction date: 06/01/1995
Manufacturing process: 0.35 micron
3.3 million transistors
Speed (MHz): 133
Bus frequency (MHz): 66
Clock multiplier: 2
Floating Point Unit: Integrated
ICOMP 2 index: 111
Min/Typical/Max power dissipation (W): 1.7 / 4.3 / 11.2
Upgrade options: Pentium MMX overdrive 166
Pentium MMX overdrive 200
CPUID: 052Ch
252Ch
Manufacturing stepping: cC0
Notes on sSpec SU073:
The part is not tested to support 82498/82493 and 82497/82492 cache timings.
Introduction date: 01/04/1996
Package: 296-pin Staggered Plastic Pin Grid Array, 1.95" x 1.95" (4.95 cm x 4.95 cm)
Speed (MHz): 166
Clock multiplier: 2.5
ICOMP 2 index: 127
Min/Typical/Max power dissipation (W): 2.1 / 5.4 / 14.5
Upgrade options: Pentium MMX overdrive 200
Core voltage (V): 3.4 - 3.6
CPUID: 052Ch
Notes on sSpec SY037:
DP, FRC and APIC features are not supported on these parts.
Modifié en dernier par Casio le 28 sept. 2026, 12:40, modifié 2 fois.
Introduction date: 06/10/1996
Socket :Socket 5 or Socket 7
Speed (MHz): 200
Clock multiplier: 3
ICOMP 2 index: 142
Min/Typical/Max power dissipation (W): 2.5 / 6.5 / 15.5
CPUID: 052Ch
Notes on sSpec SY045:
This part also ships as a boxed processor with an unattached fan heatsink.
Modifié en dernier par Casio le 28 sept. 2026, 12:40, modifié 1 fois.
